Thread: I am having trouble maintaing FC level.
    May 2012
    Oconee, Georgia
    82
    FC 3.5
    TA 80
    CH 250
    ph 7.4
    cya 70
    I have a pentair IC40 vinyl liner. We went on vacation last week and my nephew was looking after the pool. They splashed a lot of water out of the pool and pump was catching air not making C. The water is very clear but I can't maintain FC level. I am at 3.5 with running in super chl mode. My question is can you need to shock pool even if it is clear?
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Re: I am having trouble maintaing FC level.
    Sure you can!
    Run the OCLT first to see if you have something eating your FC.
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    You sure can. Use bleach. And it is safe to swim in up to shock level, so you can target 28 and still be okay to swim!
    If you lost a lot of water, you also lost the corresponding amount of salt and CYA, so you ought to confirm those.
    May 2012
    Oconee, Georgia
    82
    Thanks for the advice I have had my pool for a year now and this is the first time I have had to shock it
