Thread: pressure guage
    Jul 2014
    Lancaster PA
    24
    pressure guage
    I have a hayward cc1500 pump with default pressure guage which is a little broken okay a lot broken. Does anyone know will the glycerin filled rear mount 2.5inch one on tftestkits.net will work?
    Thank you,
    Shawn
    Pool - AG 12000 Gallon 14 years old
    Hayward Xstream CC1500 with the same pump that came with it.
    22,551
    Re: pressure guage
    The CC-1500 is actually the filter.
    The description of the part says that it's a 2" gauge so it may not fit. However, it's easy enough to tell if the gauge will fit. Go measure the diameter of the recess that the gauge is installed in now and of it's 2½" or greater it'll work just fine. If it isn't 2½" you could still use the gauge by installing a short ¼" nipple and coupling on the back of the gauge and then screwing that into the adapter in the filter. It would protrude above the filter a bit, but that wouldn't hurt anything. You could also use a bottom mount gauge if you did that. Reading a bottom mount gauge would be easier because you could turn it to a convenient position.
