Results 1 to 9 of 9
Thread: Possible very slow pump leak
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    I noticed that my hayward pump is either condensing or leaking very slowly at bottom. It's 10 years old at least. Should I just run it until it dies? It works perfect without problems and never loses suction. Can I just run it like that? The lady before me probably did not think anything of it. I am leaning towards spending $350 on a new one rather then trying to fix, as i don't know if it's worth it.
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Possible very slow pump leak
    Look closely at the motor/wet end connection point. It could be something a simple to fix as the shaft seal. Better to try that (cheaper too!) than give up on it. While you have the unit apart if it is the seal, replace the motor bearings.
    Jul 2014
    Liverpool NY
    121
    Ok so my other question is if I decide to run it like that until it dies, how bad is such a leak or the pump and how much time might I have approximately. As I said it primes perfectly and you can't hear any air, only humming. I hate to put in $50-100 and then still have the leak or even worse more problems and on top of that then the motor dies with my luck. It seems the lady before me did not seem to care or notice. Who knows how long. I tend to be OCD about stuff but if I can get by with this I will, as it's 10 years old anyways.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    No reason it shouldn't last another 10 years. The seal kits are only $25-35, depending on pump model, and are easy to install. Motor bearings are probably $15 each, so I'd say money well spent.
    If you are set on replacement, get the 2 speed motor, and a seal kit for your pump.
    Jul 2014
    Liverpool NY
    121
    Ok will go to pool store and get the seal assembly replacement, which is the ceramic thing with the springy rubber thing, and try to replace. They have it for $16. I am handy with stuff but not sure how high the screw up factor is when doing this? Wish me luck! Otherwise if it still leaks after then I don't care.
    Jul 2014
    Liverpool NY
    121
    You guys are awesome! Went to pool store and got the seal assembly kit with springy thingy and ceramic seal. Replacement was a breeze. I only had to remove the switch rather than capacitor to stick the wrench in to remove the impeller. It was pretty easy. No more leaking. I am not scared of pool pumps anymore especially not Hayward! Cost was $16.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Great!
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Good job!
    Jul 2014
    Liverpool NY
    121
    My pump is paper dry this morning. No leaks, thank you everybody...
