Thread: slamming needed ?
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    slamming needed ?
    so since our pool was finished in late March I've been fairly diligent in sticking with the TFP method
    I was out of town for about 10 days & left the pool at
    FC 7.2 CC .2 PH 7.5 TA 110 CH 280 CYA 40 (June 28)
    My friend watching house/pool & swimming didn't make over as often as I hoped so I came back to a pool with (left some powdered calcium hypochlorite since my CA could still rise & it's easy)
    FC 0 CC .6 PH 8+ TA 90 CH 290 CYA 40 (July 7)
    So I added some basic liquid chems over a couple days with these results
    FC 4 CC .2 PH 7.2 TA 60 CH 290 CYA 40 (July 8)
    FC 3 CC .2 PH 7.2 TA 60 CH 290 CYA 40 (July 9 day)
    added 256 oz of 10% liquid bleach that night so it should have gone to FC 12 (I think)
    and enough liquid stabilizer to raise CYA to 50 (pool has NO shade so thought I'd bump it)
    then morning of July 10
    FC 9 CC .4 PH 7.5 TA 70 CH 290 CYA 40-50
    evening of July 10
    FC 5.6 CC .4 PH 7.5 TA 70 CH 290 CYA 40-50
    also I use a Taylor Speedstir now & I noticed that often after I complete the CC test as the sample sits their some pink will creep back into the water
    then if I add a drop it's gone again , is this typical ? should I be calculating the extra .2 CC after the water sample sits for a few minutes ??
    Soooooo , potential algae problem ? time for a SLAM ? OCLT test ??
    Wife & kids leaving town for a week & I have the time .........
    oh & somewhere in there I added a some baking soda to bump TA with theMA I keep adding to lower PH
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: slamming needed ?
    FC/CC test will turn pink by itself if you leave it sitting. Ignore that, no need to calculate the extra.
    Also, I'd advise switching to a 10ml sample to save reagents, each drop is 0.5ppm and it is accurate enough.
    Yes, perform OCLT to see if you have any organics.
    Casey's Avatar
    SW PA
    10,423
    If you lose more than 1ppm tonight, SLAM it. If not, raise the FC to your target range and enjoy.
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Thanks for the feedback Abigail & Casey
    So this morning my test results where ........
    FC 4.8 CC 0 PH 7.5 TA 70 CH 290 CYA ??
    I'll test CYA later when there's more full sun but it should be 40-50
    So I guess the water is OK
