Thread: Success!
    Jun 2014
    Southern, CA
    14
    Success!
    Replaced an old-style Jandy AquaPure 1400 sensor (which failed) and cell:
    with the new-style sensor and cell:
    I purchased a half-union for the heater (off screen below the photos), and redid the piping from there all the way to the pipe that goes underground to the pool returns. There just wasn't any space between the fittings to do anything easy in the original piping... and the unions on the old Jandy design and the new Jandy design don't fit each other. We added a union where we cut the pipe headed underground rather than just use a coupling.
    Also extended the vertical pipes to raise the cell a few inches. Otherwise the sensor was going to be too close to the outlet pipe of the pump to be easily removed.
    PVC work is not really one of my skills, but thanks to some helpful people here we (my son and I) were able to get this repair done!
    Anybody need one of the old-style AquaPure 1400 chlorine-production cells? The one I took out was working fine, it was just the sensor that didn't work. It is eight years old though...
    13K gal in-ground plaster/3M-Colorquartz, 1HP Pentair WhisperFlo WFE-4, Pentair SMBW-4060 DE filter, Pentair MiniMax 400DV heater, Jandy AquaPure 1400 SWG, Jandy AquaLink RS, Poolvergneugen cleaner.
    Casey's Avatar
    SW PA
    10,421
    Re: Success!
    Congrats on the fine handy work and saving yourself money by doing it yourself with your boy!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Re: Success!
    Very nice, clean work in a tight area. Great job!
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
