Results 1 to 7 of 7
Thread: Help!!! New pool and I've already messed up
    Jul 2014
    Nashville TN
    3
    I got a new above ground small pool last weekend. Today the water was cloudy and the bottom of the pool was slick as ice. The ph level was perfect but didn't even register any chlorine level. I "brushed" the bottom and sides. Added shock, replaced the filter and added chlorine. Just vacuumed the pool and cleaned it out. Now the ph and colorine levels are super high!!! What should I do? I'm new at this. Sorry!!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Help!!! New pool and I've already messed up
    Welcome to TFP!
    Check out http://www.troublefreepool.com/conte...emporary-pools
    Shock and chlorine are the same thing, and will need to be added at least daily. Now that you have algae starting you may need to maintain the higher chlorine level for a few days to get it under control.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by Poolhelpplz View Post
    First, relax!
    If there's algae in the water, your chlorine level won't stay super high for long. Second, if the FC level is above 10 and you're using the red drops for pH, it will give you a false high reading because it reacts with the chlorine. Recheck it when the chlorine level drops. Keep brushing the slimy spots, that'll get a good kill on the algae and lower that FC.
    Now... what exactly did you shock the pool with?
    Oh, and welcome!
    Casey's Avatar
    SW PA
    10,428
    You need to read ABC's of Pool Water Chemistry.
    Jul 2014
    Nashville TN
    3
    Thank you for your help. I am using red drops for ph testing. I used Aqua chem pool shock 1 pound. As of this morning both levels are still high going to brush the algae spots again. Again thank you for helping.
    Richard320's Avatar
    Jan 2010
    18,984
    Just for giggles, I checked up on that stuff. It looks like it's dichlor. If you have a smallish pool, say 12 ft round by 3 ft deep, that pound of powder raised FC to 27!! And that's in addition to whatever "chlorine" you added.
    But that's all just a guess. It would really helpful if you could tell us how big the pool is and what equipment you have and what test kit you're using. Instructions on how to fill out your signature are here: http://www.troublefreepool.com/conte...efore-you-post
    Jul 2014
    Nashville TN
    3
    One one inch tablet of chlorine was added yesterday when shock was added. So if the chlorine is that high I guess no one needs to be swimming today?
    I have a 12' x 30" Summer Escapes Metal Frame pool. Has a skimmerplus 600 pump and uses a type D summer escapes cartridge. Says it holds about 1350 gallons of water. Testing kit is aqua chem 3-way test kit.
