Thread: CYA while SLAM
    DJSO's Avatar
    Oct 2013
    Cleveland, OH
    24
    CYA while SLAM
    My SLAM process isn't quite done yet. Very clear water, but just a little green in the deep end.
    My readings after returning home from work are:
    FC-8
    CC-1
    TA-130
    PH- 7.2
    CYA- 0
    Do I add CYA at this point, or wait until done with SLAM process?
    13,000 gal, IG vinyl, Jandy CV 340 cartridge filter, Jandy 1.5 FloPro pump, inline auto chlorinator, Legacy LRZM heater, Jandy waterfall pump, Automatic pool cover. Hot Springs Spa ~ Flair 326 gal with Ace Salt Water System.
    Casey's Avatar
    SW PA
    10,423
    Re: CYA while SLAM
    You should add CYA ASAP! You are losing your FC to the sun for everyday that you have none which is prolonging your SLAM and essentially wasting chlorine.
    You will want to target 30ppm for right now.
