Thread: Pool Cleaner Frequency - Question from Pool School
    Apr 2014
    Northern Virginia
    11
    Hi, Pool School, under Basic Pool Care Schedule, suggests running the pool cleaner (I have a Polaris 380) once per week.
    At my pool currently, I have it running on a timer every day for a subset of the hours I run the main pump.
    I assumed that running the cleaner daily kept the pool clean and moved the water around. Should I revisit this and move to a weekly schedule? Or perhaps I should determine my schedule by looking at the amount of debris collected?
    34K, IG, Charcoal Marquis aggregate finish, Jandy stealth pump, cartridge filter, Built '07, TFT-100, Aquapure SWG, Solar heating with Goldline controller, Polaris 380 Blackmax
    Mar 2014
    Las Vegas
    288
    Re: Pool Cleaner Frequency - Question from Pool School
    Mine runs when the pump runs. The only time it comes out is when the yard apes go in.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
