Results 1 to 8 of 8
Thread: TF-100 testing questions
    Jul 2014
    Orlando
    18
    I have just ordered my TF-100 and looking forward to it very much
    questions
    1: What levels should all my chemicals be at, please provide a 'table'
    2: does the TF-100 have a tutorial booklit? looks a little confusing, the color coding this is hard because you really cant tell the level all that well
    3: how often should i test everything?
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Re: TF-100 testing questions
    You should read the pool school information, getting the test kit is a good move...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Jul 2014
    BH (Saratoga Area), NY
    62
    I literally just got mine today and tested it out. Took a little while (half hour or so) since I was being very cautious but its all very easy and straight forward directions very detailed and easy to follow cheatsheet is provided.
    Upstate, NY, Direct Sunlight, Above Ground (18'x 33' x 4'), Oval 15700 gallons, Vinyl; Hayward S180T sand filter; 1 HP motor; TF-100
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Quote Originally Posted by Eddy24 View Post
    I agree, I just got mine a couple of weeks ago and it's very easy. I got the SpeedStir which makes things that much easier. Plus i feel like a Mad scientist doing the testing
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Speedstir! HA! All I did last year was listen to you people brag about the speedstir. SPEEDSTIR THIS and SPEEDSTIR THAT. Are you too lazy to swirl????? Then..... ahem... I bought one. And hung my head in shame. I had condemned all of you, yet now I have become one of you. Now I tell my friends "Ya gotta getta speedstir!!" They say "Are you too lazy to swirl"?
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Casey's Avatar
    SW PA
    10,448
    Quote Originally Posted by GreatCanadian View Post
    Yes I am!
    Jul 2011
    844
    Lol..... Good, honest answer!!
    Bestway SWG
