Thread: Pentair Pump Not Starting
    I'm having issues with my pentair whisperflo pump, it start making a noise when it starts and now suddenly it some times starts with the timer and other days it won't start, when I go and start it manually I get the noise on the youtube video attached and it will only start after I try for a third time, I already check the impeller and is moving fine.
    http://youtu.be/_QiWcH8B2aE
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Pentair Pump Not Starting
    Could be a bad capacitor (in the hump).
    https://www.youtube.com/watch?v=iRt9WYK1wdQ
    Mark
