Thread: New stain and Tile Question
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    stairs1.jpgtile1.jpgSTAIN ON STEPS: I have a brand new spot that came up on the stairs tight after the bug guy was here and he put down some checmichals on the lawn. Any ideas? It is light brown. I don't see any others.
    TILE QUESTION: What's the best way to clean tile? Some of my tile seems to be developing a whitish line around the tile. What is this - calcium?
    PICS attached
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    Jul 2011
    Arizona & California
    805
    Re: New stain and Tile Question
    Yes, the white lines around the tile grout is calcium leaching out. Really can't stop that from happening.
    Dilute acid 50/50 with water in a plastic squeeze bottom and squirt onto the tile grout to perhaps remove the brown. Be careful to not add too much acid at one time. And check the pH afterwards, and adjust if needed.
    The spot in the plaster might be from within the plaster and might not be able to be removed, but you could also try the acid also on that spot.
    Feb 2014
    Georgetown, Texas
    57
    Thank you for your reply. You mean Muriatic acid and water? Also, the tile grout is the color brown so I wouldn't want that to change. so the Muriactic acid and water will remove the calcium leaching?
    Judith and Brian D
    Jul 2011
    805
    My mistake about the grout color. Sorry.
    Yes, use "muriatic acid" and tap water. The acid may remove some of the calcium, but it will probably return again in time.
    Feb 2014
    Georgetown, Texas
    57
    what do you think about doing this procedure? Pumice stone and hydrochloric acid? Will the hydrochloric acid mess up my pool chemistry?
    http://www.youtube.com/watch?v=G3UcRrmN29U
    Also, just for fun - check this out. They use glass beads, then vacuum them up from the bottom.
    http://www.youtube.com/watch?v=1G5IkugAMu8
    Judith and Brian D
    Jul 2011
    805
    Yes, the acid will lower pH and alkalinity.
    The Pumice stone may work.
    But your situation is a little different, and I am doubtful that the glass bead program would be effective. The glass beads program works well on common and uniform calcium scaling on various surfaces.
