Thread: Bioguard SILK STICKS
    Jul 2014
    SUMMERVILLE
    2
    Is there something else I can put into the skimmer that will work just as well but cost less?
    Casey's Avatar
    SW PA
    10,427
    Re: Bioguard SILK STICKS
    Welcome to TFP dmcavoy06
    We don't recommend the exclusive use of sticks or pucks here at TFP because they are always adding other chemicals to the water.
    You can see what we do use here Recommended Pool Chemicals.
    I would also like to recommend to you, the ABC's of Pool Water Chemistry.
    We take a hands on approach here at TFP when it comes to dosing our pools, unless a SWG is in use, but still, the water is being tested daily even with a SWG.
    If you are more interested in not having to dose your pool daily, I would suggest you look into a SWG.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,968
    Welcome!
    Sorry, but any dry form of chlorine is going to add some unwanted byproducts - calcium or cyanuric acid. This article goes into greater detail.
