Thread: on total alkalinity
    Jul 2012
    Whidbey Island, WA
    397
    on total alkalinity
    Hi
    at
    <http://www.poolhelp.com/handouts/oB_A%20Deeper%20Look%20at%20Alkalinity%20Handout.pdf>
    there is a pdf on total alkalinity
    do you all agree with the content?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: on total alkalinity
    Sounds right.
    OnBalance is one of the experts here: http://www.troublefreepool.com/members/24406-onBalance
    Overall it is quite good.
    It does fail to note that higher TA levels plus aeration drive up the PH faster than lower TA levels. It also fails to mention that borates also buffer PH, allowing lower TA levels. Those are minor points in most cases, but very important to some people.
