Thread: Backwashing
    markuszoom5's Avatar
    Jul 2014
    Liverpool NY
    121
    Backwashing
    My pump backwashes really fast and I lose water fast. Should i backwash when psi rises even by 1 or 2? Why should I strain the pump by not bringing it down to base reading? What do you all think? I like my jets on full strength.
    Circa 20,000 gal IGP, 12 years old, Hayward SP2607X10, 1 hp single speed pump, Hayward S244T Sand filter, vinyl liner, using Aquacheck test strips and Taylor K-2006 Test Kit, 1 skimmer, 1 bottom drain, 2 jets (near stairs and on the opposite deep end)
    30,431
    Re: Backwashing
    About the best "spot" for backwashing most systems is when psi increases by 25% from clean pressure. It is a good guideline.
    May 2014
    Oro Valley, AZ
    120
    Re: Backwashing
    After I backwash my pressure is 5 psi so 1 to 2 psi would be 25% but that just seems crazy to me to backwash because of a couple psi. So I usually backwash every 2 weeks or if it gets above 10 psi or if the creepy doesn't seem to be moving normally. I kinda like my waterfall feature because I can look at it from inside the house and know if there's a pressure issue. I'm thinking of upgrading my system soon though so I'll probably be able to just look at a computer screen.
    Gil
    In-ground: 20,600 gallons; Sand Filter 1HP pump; Kreepy Krauler; Solar Breeze Solar Powered Robotic Skimmer; TFT-100 test kit
