Results 1 to 12 of 12
Thread: Plumbing question
    May 2013
    Allen, TX
    110
    Plumbing question
    Is there a way to reuse the jandy valve on the left if I plumb into that section with a swg?. It looks to me like I will need to cut it out on the vertical pipes since the run between the filter and the valve has a bunch of jogs and no place to plumb in the swg. The swg would go into a new section that leaves the filter and goes back then up and then front to drop back down to jandy valve.
    ~15K gal, IG gunite with new Wetedge Satin Matrix Pebble Finish installed mid 04/14, 1 HP Pentair Challanger pump, Sta-rite System 3 300 sqft cartridge filter, G3 cleaner
    38,251
    Re: Plumbing question
    Hard to see. Can you add a closer picture of the valve and plumbing in question?
    You may be able to use a short section of smaller pipe and glue it to the inside of the valve.
    May 2013
    Allen, TX
    110
    I will take a better pic tonight. Thanks
    May 2013
    Allen, TX
    110
    Here is a better shot.
    38,251
    Is that all 2" pipe and fittings? If so you should be able to use a short section of 1.5" pipe into the 3 way valve and immediately use a reducer back up to 2" pipe.
    May 2013
    Allen, TX
    110
    Is that much head loss going down to 1 1/2 for that short section?
    38,251
    It would not even be noticeable.
    May 2013
    Allen, TX
    110
    Ok thanks for the quick answers!
    May 2013
    Allen, TX
    110
    Here is the dry fit pics
    May 2013
    Allen, TX
    110
    And the final waiting to cure and then crossing fingers for no leaks!
    May 2013
    Allen, TX
    110
    Overshot the salt by a little but everything looks operational.
    Jun 2014
    860
    Overshooting the salt doesn't matter much unless you go WAAAY over. Also, the SWG units typically have a +/-400ppm accuracy. I would suggest getting an independent test of the salt concentration (either Taylor drops or AquaChek strips) just to keep an eye on your independent salt value versus what your machine reads.
    My IC40 always reads high by about 500ppm or so relative to my AquaChek strips. The problem is my salt can go low but my IC40 says everything is ok. So I like to try to shoot right in the middle if the two.
