Thread: Pool Math Calculator
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    The suggested FC levels it says SWG 4 NORMAL 6 To 11.
    these are my numbers
    FC 7
    CC 0
    PH 7.6
    TA 75
    CH 350
    CYA 75
    should I shoot for the FC 4 or keep it between 6 & 11
    Thanks
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: Pool Math Calculator
    For a SWG, use 4. That's the minimum FC. If you drop below that, crank the SWG up a notch. Personally, I'd target something like 6, since it builds in a cushion in case you have a sudden demand on the chlorine. It takes a SWG a few hours to build up the levels, whereas with a jug, it's just seconds.
    The last box on poolmath will let you set up targets. Choose SWG and it will set it up for you in the rows above.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    That is what I am shooting for is 6, but it goes to 7 then back. I have my SWG at 20...and its been holding the FC..
    Thanks
    Autopilot SWG
