Thread: Thank You! And what actually are those R0600 regents?
    Jun 2014
    Scituate, MA
    25
    Hello,
    I just donated to TFP. I am so grateful for your help with my pool. Just had it all done over and I learned form you how to manage my pool myself. I'm looking forward to having a safe pool to swim in, have it last, and saving money running it.
    Also, can you tell me where I can find out what the regents actually are and what's happening when they mix to get the readings. I'm a curious lady, just like to know things.
    Thanks again, Patty
    Gunite Pool Inground, Plaster, Built 1982
    20 x 40 paisley, 8 deep end, 3 shallow end, 26,000 gal - 30,000 gal ??
    Filter - Apolo Mode VA 38, 38ft, pressure 50lbs, flow rate 95 GPM, 22 lg., 40 deep, 20 wide
    Model No. C48K2PA105C5, 1 HP 115/230 3450 RPM 60 HZ
    Re: Thank You! And what actually are those R0600 regents?
    There is lots of information about the tests and the reagents here.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Quote Originally Posted by PattyA View Post
    Hello,
    Thanks again, Patty
    Maybe post 6 has the answer you want.
