Thread: CYA Article found by Kent Williams EXecutive Director of PPOA
    Jul 2014
    Lancaster PA
    24
    This might be on the forum already but after doing some research I found this and it is a very easy read with-out a bunch ofChem-Geek speak (this coming from a Tech-Geek, lol). To large to upload so here is linkl
    Link
    Thank you,
    Shawn
    Pool - AG 12000 Gallon 14 years old
    Hayward Xstream CC1500 with the same pump that came with it.
    Re: CYA Article found by Kent Williams EXecutive Director of PPOA
    This article has been discussed extensively several times before, for example here.
    It has an interesting mixture of exactly right, somewhat misleading, and dead wrong. In particular, their chlorine "staying power" graph is wrong. Higher levels of CYA continue to reduce chlorine loss to sunlight significantly, much more than their graph shows. Their bug-killing-power chart is misleading because you should be raising the FC level at higher CYA levels, which will restore the kill times observed at lower CYA levels. At the same time, their pushing people to be more aware of their CYA levels is very appropriate.
