Thread: OCLT - SLAM FC required?
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Is OCLT valid as long as FC is appropriate for CYA and no chlorine is added overnight, or does OCLT require SLAM FC?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: OCLT - SLAM FC required?
    OCLT works best when your FC is elevated at or near SLAM level, you can run it at your normal proper FC level, but the results are less conclusive than they would be at elevated FC levels.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    And if you have SWG make sure it is turned off for OCLT.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
