Results 1 to 13 of 13
Thread: Pool chemical safety/ newbie!
    Jul 2014
    Orlando
    18
    Ive gone to this site before, i am 15 and love my pool, but havent used it in about a year, its pretty clean it gets brushed once a week, we keep 2 tablets of chlorine in the system always, but a piece of dog poop has fallen in maybe once a year
    We have a nature2 and a cartridge filter, with a skimmer and a floating chlorine inserter also, there are lots of bugs floating on top and there all dead
    my questions
    1: how can i get rid of the dead bugs there super tiny
    2: is my pool safe even if dog poop has fallen in(its gone now)
    3: is 3, 3 inch tablets of 12oz chlorine good for my pool
    Re: Pool chemical safety/ newbie!
    Welcome to TFP!
    1) They should be cleared by the skimmer. You may need to adjust the circulation so the skimmer skims more efficiently.
    2) You should raise to shock level for 24 hours.
    3) 3 tablets is too much for 8,000 gallons. Keep in mind that tablets are not a great idea in the first place. Tablets constantly add CYA, which will eventually get too high, causing serious problems.
    If you post a full set of test results we can give you much more specific advice.
    Jul 2014
    Orlando
    18
    Ok sweet, this weekend im doing a lot for my pool, adding a new Nature2, i am gonna buy some test trips from my pool store hopefully those are good enough and were gonna get our water tested at the store
    Want me to take some pics of my pool for just a quick scan of any advice you guys have?
    Jul 2014
    Orlando
    18
    Slightly cloudy pool
    Merged by moderator. Please keep your related posts together for continuity of story and so as to not repeat questions. Thanks, jblizzle.
    I have an 8,000 gallon pool, i have 3 8oz tabs of chlorine in my special dispenser that floats around
    I use a cartridge filter and a Nature2, i washed my filter yesterday and shocked it, it has adequate chlorine, and the filter is kinda clean, a little green but it needs replacement anyways
    my pool is sparkly and nice, i brushed it and the floor is pretty clear but the pool is slighly cloudy, i dont know how though
    Aug 2010
    Dallas, TX
    4,052
    Re: Slightly cloudy pool
    Effectively removing algae takes more than just a single addition of a shock product.
    Start by reading through the SLAM process in Pool School:
    http://www.troublefreepool.com/conte...tain-shockingl
    Also, we need a full set of pool test results, and please include the method used to get the results. Best results are gained by using one of the recommended test kits such as the TF-100 from http://www.tftestkits.net.
    If you search on Nature2, you'll find they aren't much loved around here. Metals cause issues in pool water.
    38,403
    We do not recommend the use of nature 2 due to the added copper leading to possible staining and green hair. Return it if you can.
    No the test strips are not good enough and pool store testing is almost worse as it can be so inaccurate and comes with horrible advice.
    Jul 2014
    Orlando
    18
    I dont have a TF-100 kinda pricey, will test strips from the store suffice? and i shock once a week
    38,403
    If you maintain adequate FC which is a function of your CYA, then there is not need for a weekly "shock".
    TFPC is based on accurate testing and adding only what the pool needs.
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by JasonLion View Post
    Keep in mind that tablets are a great idea in the first place. Tablets constantly add CYA, which will eventually get too high, causing serious problems.
    I think Jason meant tablets aren't a great idea, not are.
    RobbieH, good catch. Indeed NOT a great idea.
    Jul 2014
    Orlando
    18
    Ok so good news, im ordering a TF-100, and im gonna test my water and all that good stuff
    And what would happen if my CYA got to high?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The higher your CYA goes, the more FC you need to maintain enough to properly keep algae and organics from taking over your pool.
    Reading Pool School will tell you everything you need to know. Start with the ABCs of Water Chemistry.
    Isolated Spa - 345 Gallons
    Mar 2014
    Las Vegas
    288
    Pool School is an excellent source of information. I don't recommend reading it all at once. It will get overwhelming and your head will explode. As JVTrain said, ABC's of Water Chemistry is a very good start. Once you've been through that one a couple of times pick another subject.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
