Thread: Help!!! No bleach registering.....
    Jul 2013
    Royse City, TX
    32
    Okay, so I have had my pool up for a couple of weeks now. But having trouble keeping chlorine in the pool. I am guessing it is quickly being consumed by the Texas sun. The pool water is clear and we have been having fun, but I need help getting the chemistry right!! I appreciate all the help I can get. thanks.
    Take for instance;
    Yesterday after work about 5:30 I checked the Chlorine and PH.
    chlorine-0
    PH=7.5
    cya= I can still see the black dot in the tube
    I went to pool math and it said to add 121 fl oz bleach ( 8.25%) and so I did.
    This morning before I left for work I added about a lb of stabilizer (in a pantyhose) and put in the skimmer.
    After work today I tested the water again;
    0=chlorine
    PH=7.5
    About 6pm I added about 2 lbs of stabilizer.
    I checked water at 9:30pm still no chlorine.
    Ph is still 7.5
    What do I do now?
    Esther Williams Classic, 30' Round AGP, Hayward Pro Series Sand Filter, Pentair 340104 Dynamo 115V Single Speed
    Casey's Avatar
    SW PA
    10,452
    Re: Help!!! No bleach registering.....
    Wait a week for the CYA to register and feed your pool daily! You are losing all your FC to the sun because you had no CYA. Once it starts registering, you will have an easier time holding FC levels. Shoot for 40ppm CYA. Your target FC for the day is 5ppm without going below 3ppm FC.
    Jul 2013
    Royse City, TX
    32
    Thanks Casey.
    I was hoping you would chime in. So I need to continue to add chlorine on a daily bases until the cya begins to register?
    Should I add anymore stabilizer?
    Casey's Avatar
    SW PA
    10,452
    Wait and see what the CYA is before you add more. You don't want to over shoot and have too much as it's easier to add CYA than having to do drain refills to get rid of it.
    You will need to add bleach daily. Even I add it daily to my pool. Consider it your new puppy. lol Bring FC up to 5ppm and if you need to add it in the morning, add it and if you need to add it in the evening to bring it up, do it.
    You will hold the FC once the CYA kicks in though. Anymore questions, just ask. We're here to help you.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,410
    Once your CYA is dissolved out of the stocking it will register on the test. If you only added 1 pound it still may not register. My 21 foot pool takes about 4 lbs to reach 30 ppm. Did the first test turn cloudy at all?
    Love TFP? Become a
    TFP Supporter!
    Casey's Avatar
    SW PA
    10,452
    She added 3 lbs in all zea.
