Results 1 to 8 of 8
Thread: Accidentally bought granular chlorine instead of tablets...best way to use it up?
    Mar 2014
    Tennessee
    73
    Ran into the store and grabbed the box just like what the tablets come in...got home and opened it and I bought granular. Obviously I don't have any inline system. What's the best way to use it up? Put it in hose or a sock and throw it in a skimmer? I couldn't find any floating chlorine dispensers that would work with granular.
    32,500 gallon L-shaped IG vinyl, Built in early 1980's
    Aquabot Turbo T Jet
    Century Centurion 1.5hp pump
    Hayward sand filter: 300lb, filter rate 20GPM/ft2, flow rate 62 GPM
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Accidentally bought granular chlorine instead of tablets...best way to use it up?
    Quote Originally Posted by PoolnTN View Post
    I gotta ask, what are you doing with the evil tablets/granular? When my FIL used granular he'd disperse it around the pool. Of course my suggestion would be to sell that garbage on craigslist.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Donldson's Avatar
    NW Ohio
    2,917
    Is it dichlor or cal-hypo? Does it have anything else in it, like copper? If it is dichlor or has copper in it then you should not use it at all. If it is cal-hypo and your CH isn't too high you could use it. Very slowly pour it in front of the return to dose.
    Not that i recommend any solid chlorine
    From myHTC One via Tapatalk
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mar 2014
    Tennessee
    73
    Well $@&. Did not know that solid chlorine was a no go with the TFP method. I just knew not to use it during the SLAM because it was time release.
    I mainly got the solid chlorine to use when we were going to be away from the pool for extended periods of time and wouldn't be able to add liquid bleach for several days.
    Below is what I bought.
    Aquabot Turbo T Jet
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    I just did some number crunching.... 22.5 lbs @.718 concentration is 258 ounces of trichlor. That box will add 33 CYA to a giant 32,500 gallon pool!
    What is the current CYA level?
    Aug 2010
    Dallas, TX
    4,052
    I don't consider powders to be time release. In the case of dichlor, I spread it across the surface of the water and sweep the pool to mix it in. With your vinyl liner, you probably need to be very careful using this method to not let it sit on the liner at all. May even make sense to dilute it with water first.
    And yes, I've used dichlor. When I was starting my pool and CYA was zero.
    Donldson's Avatar
    NW Ohio
    2,917
    The "other ingredients" worries me too. Clarifier is not something you want in your pool "just because". Also it lists "sun protector", makes me wonder if there is extra CYA in it. Trichlor already has CYA like Richard pointed out, if you are already using trichlor pucks you don't want to raise it any faster with powdered trichlor or dichlor.
    Mar 2014
    Tennessee
    73
    Richard320,
    It was 35 the last time I tested but I need to retest because I've added some water and had a rain.
    RobbieH,
    Me either. I was just trying to think of a way to "sort of" make it time release by putting it in a sock or something.
    Donaldson,
    I'm not using anything at this time, other than adding chlorine (I just recently got done with the SLAM).
    Aquabot Turbo T Jet
