Results 1 to 7 of 7
Thread: Blindly SLAMing pool, now have 1st test results
    DJSO's Avatar
    Oct 2013
    Cleveland, OH
    24
    My 13,000 gallon vinyl pool turned cloudy and greenish this past weekend. I only had test strips to work with, but started SLAMing my pool the best I could. I have been getting positive results with only a little green / cloudiness in the middle of the deep end. My TF100 test kit arrived and have my first numbers and want to know where to go from here.
    FC-4
    CC-1
    TC-5
    TA-120
    PH-7.2
    CYA-0 (I tested twice after watching the video online, so I'm pretty confident. My test strip also registers CYA as low)
    13,000 gal, IG vinyl, Jandy CV 340 cartridge filter, Jandy 1.5 FloPro pump, inline auto chlorinator, Legacy LRZM heater, Jandy waterfall pump, Automatic pool cover. Hot Springs Spa ~ Flair 326 gal with Ace Salt Water System.
    Re: Blindly SLAMing pool, now have 1st test results
    You should raise CYA to 30. With CYA around 0 you lose chlorine to sunlight way too quickly.
    Meanwhile, keep SLAMing. CC is still an issue, but that should clear up soon with continued SLAMing.
    DJSO's Avatar
    Oct 2013
    Cleveland, OH
    24
    What's the best thing to use to raise CYA? It's the one chemical my pool installer didn't give me and ironically the one test they told me I would never have to worry about during my orientation.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Quote Originally Posted by DJSO View Post
    Stabilizer. It's generally 99 or 100% pure cyanuric acid aka CYA. http://www.troublefreepool.com/conte...pool-chemicals
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    You need to add a gallon of bleach at 10% this will get you up to 12 fc, that is slam level for you. Monitor FC every hour and keep it at 12 fc for now.
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    DJSO's Avatar
    Oct 2013
    Cleveland, OH
    24
    I guess I should have figured that out... I guess I've had one to many trips to the pool store where they want to sell me everything but what I ask for... Lol
    Casey's Avatar
    SW PA
    10,461
    You can get the HTH brand at WalMart. It's called Stabilizer/Conditioner. It's about $15 I think for a 4lb jug.
