Results 1 to 12 of 12
Thread: Test kit vs pool store results
    Jul 2014
    Harrod,Ohio
    5
    I am a new member and a new pool owner. I recently got my pool up and running and took some samples to the pool store. After getting tired of the test strips I purchased a pool masters basic 5 test kit from the local pool store. There test results are different from what i am getting from the kit, and i am not sure which one to even believe anymore. There results were FC .09 CC 2.32 PH 7.4 TA 172 CH 420 CYA 4 and SI .7. At the same time My results were ph 7.2 TA 200 and FC 1. They said i needed to add more muriatic acid to bring the TA down which i agree, and also to add chlorine which i did as well. Well after 24 hours i tested and got a PH 7.0 Ta 180 and FC 3. Do I need a better test kit or to keep driving to the store to get this TA issue under control. Any help would be greatly appreciated. Thanks in advance
    30' round,22,800 gallon AG, Hayward cartridge xstream 150 filter with power flow LX 1.5hp pump, aquatrol SWG, built 6-28-14
    Casey's Avatar
    SW PA
    10,461
    Re: Test kit vs pool store results
    Welcome.
    Since you're asking a very specific question, I'll answer...
    YES! You need a better test kit! A TF100 will suit you and your needs just fine and you can trust the test results and use the kit every day of the summer and still have it to start the next season. You can purchase the test kit at TFtestkits.net. You can find the link in my signature.
    Donldson's Avatar
    NW Ohio
    2,917
    Your current kit is fine for testing pH, CH, and TA. It does not test for FC, it only tests for total chlorine. Your results are trustworthy on those 3 tests, pool store results are untrustworthy for anything.
    You do need a test for CYA and a test that can test both FC and CC (the test is called FAS-DPD). You can get both of these tests from TF Test kits and add them to your current kit if you would like. Adding these will get you a complete set and let you take complete control of your pool.
    And welcome to TFP from a fellow Ohioan!
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Jul 2014
    Harrod,Ohio
    5
    Thank you! sounds to me like i need to order me a TF100 kit and forget the pool store. Any suggestions with the TA? Do I keep adding the acid until that gets under control and then bring the ph back up?
    Donldson's Avatar
    NW Ohio
    2,917
    Lowering TA in Pool School
    Casey's Avatar
    SW PA
    10,461
    TA is usually the last thing we tinker with. It is recommended that you get your FC and CYA in line and once you are stable and on the right track, you can start working on your TA by following this Lowering Total Alkalinity.
    Jul 2014
    Harrod,Ohio
    5
    Donldson thank you. I wasnt sure if that was the best way to do it or if there was a different way. Sounds like its just gonna take a little time! thanks again
    Casey's Avatar
    SW PA
    10,461
    Quote Originally Posted by Donldson View Post
    Sweet... Thanks for your help Donldson! It is much appreciated!
    Jul 2014
    Harrod,Ohio
    5
    thanks casey still getting use to pool ownership and everything is overwhelming haha thanks
    Donldson's Avatar
    NW Ohio
    2,917
    Casey is right, it is not vitally important to lower the TA. It happens naturally since your pH will rise, you add acid, TA and pH lowers, and then the pH rises again. So you don't really need to actively do much.
    Jul 2014
    Harrod,Ohio
    5
    Ok I understand now. I just ordered my TF100 kit so hopefully i can get more accurate results. Thanks for the help!
    Casey's Avatar
    SW PA
    10,461
    You will love the test kit! You'll use it everyday until one day, you will know your pool like the back of your hand. You'll then use the test kit to confirm your guesstimates because you start to know your pool's diet.
