Thread: Unlevel Pool Help needed
    Jul 2014
    Rock Hill
    2
    I am new to this site but I have been having a lot of the same issues as mentioned in this thread. First of all I did try my best to level out the pool but I was told that I could use hay ot straw under the pool in another forum and now my pool is driving me crazy. I seeing now that I leveled the liner part of the pool but I did account for the poles and I have pavers but they are to big so I did not use them and now I have a sinking feeling. I believe there is only about a 1 inch difference right now but I am SC and we get some nasty storms this time of year. Two of the poles on my pool are slightly bending to where the poles are pressing against the liner and almost bending under the pool. :brickwall. I am scared it may not hold up. We do play rather rough in the pool. I was wondering should I try to lower the back side that is a little deeper or should I jack up the low side or should I start over.
    Jul 2014
    Rock Hill
    2
    Re: New Pool Owner, unlevel pool. ugh...
    I forgot to say that I have a 15'x42" Pro Series Summer Escape Pool
    mac.dblues's Avatar
    Jul 2013
    Arkadelphia, AR
    321
    Re: Unlevel Pool Help needed
    I recommend adding pictures but I think you will find the general consensus will be to drain, remove, dig down the high side, reassemble and refill. Sorry for the bad news.
    Mac.Dblues and ProfessorDaisy's Lower Arkansas Pool Install
    Intex UltraFrame 20ft x 52in deep, 9,400 Gallons / Approx 78,500 lbs, Intex 1600 GPH, 14" sand filter, Hayward Dyna-Skim SP1091LX, Taylor K-2006, SpeedStir, Sample Sizer
    First Fill May 2014, Deck finished June 2014, Mods happening probably on a continuous basis. Stay tuned.....
    Casey's Avatar
    SW PA
    10,457
    Mac is right. If you have bending poles and did not use pavers, and you guys are horse playing in the pool (who doesn't?!!!) then you should take the pool down, re dig the bottom to level in a 16ft radius, set the pavers and reinstall the pool.
