Thread: Question on sequestering agents
    Sep 2007
    Mobile Alabama
    33
    I'm having to use Jacks metal magic for copper removal. My question is where does the sequestered metals go? Do they stay in the filter until backwashed? Do they ever leave ?
    16x36 vinyl
    300 lb sta-rite sand filter
    3/4 hp sta-rite pump
    Aquarite SWG
    Guest
    Re: Question on sequestering agents
    It stays in the water, it is just 'deactivated' so it cannot stain or cause other problems. This is why maintenance doses of sequesterant need to be added on a regular basis, to keep the metal 'deactivated'/
    Sep 2007
    Mobile Alabama
    33
    Dang...so I need to buy stock in Jack's then? How often will I have to add Jack's to keep it deactivated?
    Will the copper get lower each time I have to replace water from backwashing, splashing,or when it rains?
    16x36 vinyl
    Aquarite SWG
    Copper levels will go down slowly over time as you backwash, splash out, and otherwise replace water.
    You typically have to add a small additional dose of sequestrant once a week, though some people can go longer than that.
