Results 1 to 12 of 12
Thread: New guy 1st pool
    Jul 2014
    Virginia Beach
    9
    New guy 1st pool
    Bought this 17x48 pool and filled it with tap water. Went to store and got a test kit.
    Aqua Chem smart strips. Need idea. Dip it and upload it and it tells me what's going on. I did it and it recommends alot of chemicals already. Could this be right? Check it please.
    [IMG]uploadfromtaptalk1404942688415.jpg[/IMG]
    Thanks for the help
    ProSeries 16' X 48" Metal Frame Swimming Pool Filled 7/8/14 NEW
    No clue what I'm doing, dont follow me.
    Re: New guy 1st pool
    Welcome to TFP!
    No water testing system that uses test strips is reliable enough to be useful. You will be far better off getting one of the test kits we recommend.
    Jul 2014
    Virginia Beach
    9
    OK so another $10 down the drain. What do you recommend that I can get locally?
    Btw thx
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    What all have you added since you filled? It has your CYA at 250. That is pretty high for a new fill.
    May 2014
    Virginia Beach, VA
    56
    Quote Originally Posted by PAGirl View Post
    Exactly what I was going to say!! Theres no way you have CYA at 250 with a fresh tap water fill alone.
    ...and another Virginia Beacher...Welcome!!!
    24' Round Above Ground - 13,500 gal, Cartridge Filter, Installed on 5-7-14, First Time Pool Owner! TFP True Believer!
    Mar 2014
    Las Vegas
    288
    The test kit most recommended here is the TF-100 available online. I doubt if you will find it in a pool store. Some information about your pool would be helpful. Gallons, Fiberglass/Vinyl/Gunite, Pump Size, Type and Size filter, and info about any other equipment you have.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Jul 2014
    Virginia Beach
    9
    Just filled with tap water. Nothing added.
    Cheepo pool. 16'x48" round 5100gal. Stock cartridge filter for now. 1500gph.
    Reading about all this makes my head hurt. I don't need a new hobby/project just trying to keep kids happy. Is salt a better alternative. Don't mind spending a little more for less hassle.
    Icemanva where in the beach?
    Jul 2014
    Virginia Beach
    9
    Well TF-100 on the way. Get back to you in a few days when it gets here.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by IcantDo55 View Post
    Keep/maintain about 2ppm FC for now. Use PoolMath to figure the doses. Post back if you need help.
    Welcome to TFP
    You're done SLAMing when:
    Jul 2014
    Virginia Beach
    9
    Here is the El cheepo Kmart test kit results until new kit gets here.
    Got a lot of rain here today and pool looking kinda green. All that has been added since fill is two 1" chlorine tabs.
    Mar 2014
    Las Vegas
    288
    2 1" tabs probably won't get you to 2ppm as previously recommended. You need to get some bleach in there soon before the green gets out of hand.
    Jul 2014
    Virginia Beach
    9
    According to that posted drop kit and this strip kit it's currently over 5ppm. Right? uploadfromtaptalk1405038398581.jpg
