Results 1 to 7 of 7
Thread: YMCA Pool in Edgewater MD Sends 35 to Hospitals
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,275
    Looks like a pump broke and dumped either a lot of MA or CL into the pool. Hope everyone makes a full recovery.
    http://baltimore.cbslocal.com/2014/0...-at-ymca-camp/
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Aug 2010
    Dallas, TX
    4,052
    Re: YMCA Pool in Edgewater MD Sends 35 to Hospitals
    Idiocracy is coming...
    "It was originally reported that this was a chlorine incident. We have since learned that the chemicals that the people were exposed to were sodium hypochlorite..."
    38,301
    It would be nice if a few of those statements were complete sentences. I am not sure what a few of them were meant to say. Reporting at its finest.
    Aug 2010
    Dallas, TX
    4,052
    Agreed
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Antibiotics for chemical exposure ???
    Riiiiiiiight!
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Nothing they said about what happened makes any sense at all. The symptoms described are chlorine gas symptoms, and one of the firemen said the chemicals were "bubbling up", but much of the rest of what they say seems to contradict that. My over all impression is that no one on site actually knew what was happening.
    Trying to put the pieces together so they make sense, and therefore ignoring about half of what they said, I suspect they had high flow rate injectors for both bleach and muriatic acid setup so that only one could feed at a time. If something broke somehow (because of the storm???) so that both bleach and acid were feed in at the same time, that could create chlorine gas. But for that to happen the injection rates would have to be pretty high, higher than would normally make sense. But 9/10ths of this is guessing. The story is just too garbled.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Thimble View Post
    Riiiiiiiight!
    "He also said that antibiotics do nothing in a case like this..."
    O RLY? I thought antibiotics were great treatments for chemical exposure, viruses, headaches, bunions and bad hair days. Can you imagine the sequence that led to this information? Something like:
    Reporter: Will you treat with antibiotics?
    Doctor: *rolls eyes* *refrains from calling them an idiot* "In cases like this, antibiotics do nothing." *promptly walks away*
    Isolated Spa - 345 Gallons
