Results 1 to 12 of 12
Thread: How much bleach?
    Jul 2014
    Fresno ca
    4
    How much bleach?
    I have a 13' above ground pool that holds app. 2500 gallons.
    I got the water clear with 5 96 oz household bleach but it still registers as 0 when i do the chlorine test. How much do I need to get it to 3-4 ppm?
    Casey's Avatar
    SW PA
    10,457
    Re: How much bleach?
    Welcome to TFP.
    Please post a full set of test results including:
    pH
    TA
    CYA (most important)
    Aug 2010
    Dallas, TX
    4,052
    Welcome to TFP!
    FYI, PoolMath at the top of the page will help you know how to dose the pool. Problem is, if it's getting eaten quickly, you may have a problem with algae.
    Jul 2014
    Fresno ca
    4
    I tried pool math but apparently didn't use it correctly because it told me to add 5 oz!
    I don't think my test kit has CYA it's a 3 step kit from I think HCH
    I'll post more info when I return home
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,106
    What chemicals have you added in the past? This article gives more details in dealing with seasonal pools.
    Welcome to TFP!!!
    Oct 2012
    Houston, TX
    186
    5 oz won't do anything. Please put all of your pool specs in your signature. It will help everyone answer your questions.
    Adding an amount of chlorine to achieve a certain ppm level isnt a 1 time deal, you have to consider what is in your pool consuming chlorine aside from normal loss from sun.
    As Casey said, the other test info is crucial to answering your questions. CYA in particular.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    Casey's Avatar
    SW PA
    10,457
    Quote Originally Posted by hyperionguy View Post
    Yes. I, and others, would like to know your CYA level. If you have no or very low CYA, you are burning off all your FC to the sun. I have a hunch that this is what is happening. If you must go to the pool store for the results, it is better than nothing but please do not purchase anything. Post the results and we can go from there.
    Jul 2014
    Fresno ca
    4
    I have an hth 3-way test kit so the only test results I have available are:
    Cl = 0
    Br = 0
    pH = 7.2
    Quote Originally Posted by Casey View Post
    Welcome to TFP.
    pH
    TA
    Jul 2011
    Eastern Ohio
    7,106
    What chemicals have you ever added to the pool?
    Casey's Avatar
    SW PA
    10,457
    Hello?
    Jul 2014
    Fresno ca
    4
    Hello
    Casey's Avatar
    SW PA
    10,457
    What chemicals have you added to the pool?
