Thread: Should I raise my CYA?
    Jul 2014
    Hudson, wi
    81
    When I started testing my pool my CYA was under 20. I added about 2lbs. of CA and now it reads 20-25 maybe. I never get full sun and maybe get 3-4 hours of partial sun on my pool. I'm trying to keep my FC around 3 now and my CC is .5 or less. Would a higher CYA benefit me?
    21,000 gallon IG with vinyl liner, Pentair sand filter, TF100 test kit, pool is about 15 years old.
    new in 2016 - Hayward SWCG with T15 cell
    Aug 2010
    Dallas, TX
    4,052
    Re: Should I raise my CYA?
    If you added dry CYA, it takes about a week or so before it will register on the test completely. In WI, I would think 30 would be sufficient though.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by RobbieH View Post
    ^ +1 Especially since your pool gets no direct sun and only a couple hours of partial sun.
    You're done SLAMing when:
