Thread: TF-100 Regents $ and replacement schedule?
    Jul 2014
    BH (Saratoga Area), NY
    62
    I'm just trying to get an idea of how often I'll be going through the regents from the TF-100 (I ordered the XL). and how much each regent typically costs (if there are varied prices).
    Upstate, NY, Direct Sunlight, Above Ground (18'x 33' x 4'), Oval 15700 gallons, Vinyl; Hayward S180T sand filter; 1 HP motor; TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: TF-100 Regents $ and replacement schedule?
    Pricing is easy: http://tftestkits.net/TF-100-Refills-c11/
    How often depends on how obsessed you are with testing. You'll burn through a lot early on, but as you get used to things and get to know the pool, it tends to slack off. There's usually a sale on the refill set in the Spring, which helps some. A lot also depends on where you live, and what shape the pool is in. I go through a lot of R-0012 since my water is so hard and the Calcium test takes a lot of drops. If you're maintaining a pool with really high CYA or clearing a swamp, you'll burn through the FAS-DPD stuff pretty good.
    It's still cheap insurance. Let the pool get green and you'll spend way more than the price of the refills on bleach!
    bridgman's Avatar
    Mar 2014
    Bowmanville, ON Canada
    461
    The TF-100 reagent quantities are sized (as much as possible) so you run out of them all at roughly the same time -- vs the Taylor kits which have the same amount of each reagent**.
    ** although I recently discovered that the K-2006 includes two bottles of CYA reagent R-0013 so it's not as bad as I thought
    The kits are also shipped out through a shorter supply chain so tend to arrive pretty fresh, so if you buy at the start of one season and keep the kit in a cool dark place you should get two seasons out of it.
    You can buy a kit of replacement reagents for $39, I would think about picking up one of those every second spring even if you haven't used up all the reagents yet. You probably won't get two seasons out of the reagents in a stock kit if you have to SLAM or are running at high FC levels (so more R-0871 drops used with every test), but that's where the XL option comes in and you can always buy more R-0871 if you need it.
    For what it's worth, refills are way cheaper in the US than in Canada
    Cedar hot tub, 680 US gallons - Snorkel wood-burning heater, canoe paddle, "offline" Intex 1000 GPH pump/filter with skimmer
    For a typical situation, understanding that situations do vary, the TF100 kit should last roughly two years.
    Jul 2014
    62
    sounds good, thanks all. Kit should be arriving any day now, I'll post my first results soon. Need to study up on the testing procedures...
