Thread: Ordered SWG - Do I need to drain current chlorine pool?
    Jul 2014
    PC, FL
    9
    I have an Intex 12'x30" above ground pool and just ordered a new pump and SWG for it. Do I need to, or should I, drain the current chlorinated water and start over with fresh water for the salt/SWG?
    Intex 12'x30" (~2100 gallon) above ground vinyl pool / Intex krystal clear saltwater system / Intex 1000 gallon pump /
    Casey's Avatar
    SW PA
    10,438
    Re: Ordered SWG - Do I need to drain current chlorine pool?
    No, you don't. Add the recommended amount of salt and CYA per instructions for SWG after hook up and let'er rip!
    Donldson's Avatar
    NW Ohio
    2,893
    As Casey said, no need. The chemistry is the same, you will just run higher salt levels and CYA levels.
    Make sure you read the "Vinyl with SWG" recommended levels, you can start adjusting those levels now if you would like.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,993
    No! don't dump your carefully balanced water!
    In fact, if there are children around, hold Diamond Day. See post 5
