Thread: Small leak in pool
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Small leak in pool
    I've got a small leak in my pool that has been there for about 2 years. The pool loses about 1/8" per day which should be about 60 - 70 gal/day. I came across a comment on another forum that said cracked face plates on pool fittings could be the source of a leak. I started checking my face plates (5 total) and two were cracked. When I started replacing them I found there were no gaskets under any of them - including the skimmer face plate. Could the the lack of gaskets cause a leak and should the gaskets be lubed with an o-ring sealer when they are installed?
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    30,421
    Re: Small leak in pool
    Lack of gaskets could CLEARLY be the source. I have not put in too many gaskets but, generally, sealant is not required, I think.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    492
    Thanks Dave, on my way to buy gaskets. Maybe that will cure my problem (I hope).
