Results 1 to 7 of 7
Thread: Have a leak at a PVC joint - any suggestions?
    Jun 2013
    Philadelphia, PA
    143
    So I'm working on plumbing in the new heat pump. All was going well until one of my joints sprung a PIN hole leak. Barely noticeable; only realized it when I saw the concrete wet (After it dried from all the work I did.) See picture below. Never had a PVC joint leak before - not sure what went wrong as both the primer and glue are brand new and I gave it a slight twist when installing and held for 30 seconds.
    Problem is, there's just no room to remove that joint and start over. Any suggestions?
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Have a leak at a PVC joint - any suggestions?
    Well the good news is that if you need to cut it out you'll be able to use 2" PVC over the jandy valve. then you'll be able to use a reducer to reconnect after the flow detector.
    Jun 2013
    Philadelphia, PA
    143
    Ohhh, I never even thought about going over the Jandy! It would actually be a 2.5" PVC over it (All 2" currently.) I guess if I have to I can just cut the existing PVC flush to the Jandy and go from there.
    Good thinking! If anyone else has any other ideas, let's hear them.
    TFT 100
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    What kind of couplers are you using? They don't look like a normal coupler for what is usually used on pools. You should be using schedule 40 PVC pieces. Yours look like DWV(drain/waste/vent) which isn't for this type of plumbing work. You don't really have enough of the pipe inside the coupler A PVC coupler usually allows almost 1.5" of the pipe to be inserted into it. Your looks like maybe you have about half an inch of the pipe in it.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2013
    Philadelphia, PA
    143
    Paul - I think you hit the nail on the head. Everything I grabbed was schedule 40 in terms of pipes, elbows, etc. However, I never noticed there were different couplings for DWV versus pressure applications and it appears that's where I went wrong and didn't pay attention to what was written on the box. So I definitely think this is my issue and I have two I need to somehow replace (The other coming off the back of the filter.) This is not going to be fun. . .
    TFT 100
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    For the one closest to the filter, if you can find it, you can get inside pipe extenders, glue them inside each side of the pipe, then install the correct coupler. Or you can go the route of getting a new union for the filter and start over. When you cut off the leaking one, cut it flush with the three way valve and then get a 2.5" coupler with a 2.5"x2" reducer. The one end of the coupler would fit right over the valve as mentioned before. Then the reducer in the other end and then the pipe into it. Not sure you can find a 2.5" coupler at a home improvement store though, the schedule 40 kind.
    Paul
    Jun 2013
    Philadelphia, PA
    143
    Version 2.0. Better?
    Thanks to Paul for setting me right. I actually spent a lot of time and patience and used a few different methods and removed the existing PVC pipe from the valves and such. Started over fresh and was able to replumb everything from scratch where I had the bad union. No more leak!
    TFT 100
