Thread: TA at 120, pH at 7.5
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    My neighbor's pool has a TA of 120, and a pH that appears be locked in at 7.5. Is there any need to lower the TA? She wants to, but I told her there's not need to if her pH stays where it appears to be staying. If pH rises, the TA will drop when I lower the pH anyway. Vinyl pool, SWG, CYA 70. Thanks.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: TA at 120, pH at 7.5
    You are correct, the TA doesn't need to be adjusted to meet an arbitrary number. With a SWG, if the pH isn't drifting, then she's golden where it is.
    Jul 2011
    844
    Perfect, thanks for the reply!
    Bestway SWG
