Results 1 to 9 of 9
Thread: Starting a new topic
    Jun 2014
    wallkill,ny
    3
    Hi,
    I just registered , and noted that I am supposed to ask my question in a new thread, but I am having trouble figuring how to start one. Can someone please help me with this?
    Thanks!
    Re: Starting a new topic
    I can't figure it out either!!!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Go to the forum you'd like to post to, should be the most relevant to your question such as the Just Getting Started or TFPC Method. Blue button that says "Post New Thread"
    Isolated Spa - 345 Gallons
    Jul 2017
    Houston
    1
    i still cannot figure out how to do this - anyupdates for this latest version of the site?
    8000 gallon, kidney shape
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Click Forum in the tool bar above. Click the forum you'd like to post to, should be the most relevant to your question such as the Just Getting Started or TFPC Method. Click the blue button that says "+Post New Thread" upper left.
    Oct 2017
    Metairie, LA
    7
    There is NO BUTTON POST NEW THREAD!!!
    14,000 Gal IG Saltwater pool, Aqua Rite Chlorination, Pentair Intelliflo pump, Polaris 280 w/booster pump, Pentair clean & Clear cartridge filter
    Oct 2017
    Metairie, LA
    7
    I have selected the Forum and when I press it it just shows the list of postings and the words POST NEW THREAD are nowhere to be found!!!! Obviously others are having a problem also I have been try to post for over 30 Minutes!!!!
    Teald024's Avatar
    Aug 2016
    Columbus, Ohio
    1,109
    You were able to post in the Intro subtopic. It should be the same in any other subtopic. But it does need to be in a subtopic and not the main Forum page.
    The button is there for me.
    Dave - Aqua Leader Elegance AGP 15'x30'x 54", 12k gallons, vinyl liner ... Hayward/SwimPro Voyager pump SW159412STL, 2hp, 2spd, Hayward/Voyager 175sf element filter SW175MDDVPAKS, Installed August 2016 ... Liquid Chlorine, Stenner, Woods 50015 timer ... TF-100 .... CYA/Chlorine Chart ... Recommended Levels ... Basic Care Schedule ... Extended-Test-Kit-Directions ... ABCs of Pool Water Chemistry
    DFW, TX
    24,485
    See the button on the upper left? Right above the Just Getting Started? Straight under the Support TFP button?
    Click Forum, then click the Forum You want to post in, like Just Getting Started and then click the +Post New Thread button.
