Thread: please help with our green water!!!!!
    Jun 2014
    Maple valley,wa
    3
    Hello... we really will appreciate any help !!! we are really new on this our neighbor give us a pool intex 16'x48, we used afew weeks and turn green and my husband has tried so many things until he dumped all the water and fill it up again and also we got Intex Krystal Clear Saltwater System 15,000 Gallon and Intex Krystal Clear Sand Filter Pump that pump 2150 gallons per hour...( we got this 2 things today) the water is green again ... we we did check the water with the strips and said this:
    th 0
    fc 0
    ph 8.4
    ta 40
    cya 30-50
    we really dont have any idea what do we need to do !!!!!
    he hook the sand filter already and is running , ....can we put the salt even is green or what do we need to do!!???
    sorry !!! and thank you !!!!!
    Re: please help with our green water!!!!!
    You can start by lowering the PH to around 7.5 and then retest the TA and raise it to around 70. Then it is time to SLAM the pool (instructions in the How To section of Pool School).
    Once the algae is cleared up you will want to raise CYA to between 70 and 80, the recommended level for SWG pools.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Welcome!
    First thing you need is a decent test kit.
    Second is to adjust the pH. You could have metals in the water tinting it green because the water is so alkaline.
    Third, use bleach to kill any algae. How much depends on the CYA level. If you haven't added any, your level should be zero - so you can see those strips aren't accurate enough for this.
    Finally, when the pool is clear and balanced after the SLAM process, then you add salt and fire off the saltwater generator and enjoy a trouble free pool the rest of the summer with all your new knowledge and your test kit.
    You can do this! People have dealt with far worse. Here's some proof. Look at the pictures!
    http://www.troublefreepool.com/threa...urn-to-a-swamp
    http://www.troublefreepool.com/threa...numbers)/page2 post 37 especially
    http://www.troublefreepool.com/threa...ool-is-winning
    http://www.troublefreepool.com/threa...-to-Clean-tale
    http://www.troublefreepool.com/threa...28-TFP-Success
    Just do what they did.
