Results 1 to 7 of 7
Thread: Does adding CYA make water cloudy?
    Aug 2007
    Northern Kentucky
    20
    My water was sparkling yesterday then I added CYA in a sock hanging by the return and when I checked pool this morning the water is milky looking and cloudy, Is this Normal? If so how long do you think it will take for pool to clear up?
    27 ft. round AG pool with 54" walls, 18,065 gallons, 22inch Sparco sand filter with 2.0 HP 2 speed pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Does adding CYA make water clowdy?
    I don't think that would do it....but to help you better, we would need to see a full set of test results for your water. Do you have that, can you post it here? Then we can get a better idea of what's going on with your pool.
    Aug 2007
    Northern Kentucky
    20
    Ok I just went out and took a full set of readings on the pool, I shocked my pool wednesday evening so the fc is a little high and I got a false reading on the PH because of the high chlorine, here are the numbers.
    FC - 10.5
    CC - 0
    PH - 8.0 Due to high chlorine?
    TA - 120
    CYA - 35
    water was crisp and sparkling yesterday after shocking, I vacuumed and added CYA and today it is clowdy.
    Thanks for helping been struggling with pool this year and dont understand why
    11,969
    Hi PH combined with high CH can cause cloudiness; what is your CH reading?
    Aug 2007
    Northern Kentucky
    20
    I just took a new set of readings here are the numbers
    FC - 7.5
    cc - 0
    PH - 7.8
    TA - 120
    CYA - 35
    CH - 130
    Pool is still cloudy and I have been running my filter 24 hours a day since wednesday
    Re: Does adding CYA make water cloudy?
    If the pool is cloudy white then try bringing the PH down to 7.5 and see if that clears up the cloudiness.
    If it is cloudy green then it sounds like the algae is coming back.
    I have added several lbs of CYA via a sock.. never had an issue with cloudiness.
    2003 Marquis Euphoria - 400gal
