Results 1 to 14 of 14
Thread: Worms?
    Jun 2007
    SouthCentral PA
    13
    Worms?
    Not sure if this is the right place to pose this question, but it didn't seem to fit anywhere else.
    For the past few mornings I have noticed small worm-like creatures on our walk in steps. They appear white/ivory in the water and, when I scoop them out with the net, they seem somewhat gelatinous and translucent in appearance. I have noticed a few others on the shallow end floor, but they are primarily on the steps, or at least that is where they are most visible. They number anywhere from 3 - 10 every morning.
    Any ideas what these are or where they could be coming from? Or, better yet, how do I keep them away?
    Thanks for your help!
    30k gallon inground with vinyl liner
    Hayward cartridge filter
    Southcentral PA
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Worms?
    Gosh I hope they are not these....
    http://www.mondaymorningmuse.com/archive3/maggots.jpg
    Can you post a pic?
    Jun 2007
    SouthCentral PA
    13
    Re: Worms?
    I'm pretty comfortable it's not maggots.
    A pic will likely have to wait until tomorrow morning as I've fished out today's crop. I have "toyed" with one before while it was on the net and I can't make out any discernable features to it. It seems to lose its defined edges once removed from the water (becomes blob-like). As an added note, we have a possibility of mustard algae showing up. It has also been quite hot and humid here, causing dry conditions, and could just be dust and pollen from trees and the occasional mowing of the lawns.
    Southcentral PA
    11,969
    Re: Worms?
    Well, then how about a set of test results?
    So glad it's not maggots. I had this vision of some critter bringing his "not so fresh kill" to clean off in your pool before consuming it....
    Jun 2007
    SouthCentral PA
    13
    Re: Worms?
    Results, courtesy of my wife:
    FC - 9.5
    CC - 0.0
    TC - 9.5
    PH - 7.7
    Alk - 100
    Temp - 80
    CYA - 30
    I must say, I'm a bit suprised on the chlorine as I tested it last evening and got 4.5. I put in a gallon of the good stuff which should have yielded a 4.1 increase (per Pool Calculator). Perhaps the strength of the bleach was a bit higher than 12.5%.
    Southcentral PA
    11,969
    Re: Worms?
    Numbers look good; worms remain a mystery.....
    Jul 2008
    Central Kansas
    8
    Re: Worms?
    A friend of mine used to get slugs in his bathroom ALL the time. Mostly around the bathtub. They would squeeze through the cracks in the floor and just hang out. We had lots of fun pouring salt on them tho They sorta resembled the worms you describe, so I thought I'd mention it lol
    AG 16' x 3.6' Easy Set ~3900G
    Intex 637R Filter Pump 1/9HP 1000GPH Cartridge
    BBB, TF100, 1st year Amateur
    11,969
    Re: Worms?
    So I was bored....
    Look at the bizzarre video I found via Google
    http://www.37signals.com/svn/posts/1136 ... dian-worms
    OK. Eweee....
    Jul 2008
    Central Kansas
    8
    Re: Worms?
    Quote Originally Posted by frustratedpoolmom
    So I was bored....
    OK. Eweee....
    I saw these on "The Most Extreme" show on animal planet! Very strange to say the least.
    Jun 2007
    SouthCentral PA
    13
    Re: Worms?
    Now that's just plain creepy. How did that thing fit in the cricket?
    Anyway, go figure, there was none this morning to take a photo of. I'm glad, but now somewhat disappointed in a strange way that I can't share this with you. FYI - I've never seen them move, which makes me happy.
    Also, I tested the chlorine after sun down last evening and got 5.5, which I guess isn't too surprising to see a 4 ppm drop given it was a full day of sun and 90 degrees (with a CYA of 30). Tested again this morning and got 5.0, so I don't think I have anything to worry about with organics in the pool. Someone want to reassure me on that one? I've got a pool party later today.
    Thanks to all.
    Southcentral PA
    11,969
    Re: Worms?
    Your good! Have a great party.....
    Jun 2007
    SouthCentral PA
    13
    Re: Worms?
    Well, they are back this morning. The only thing I can think as to why there were none yesterday is that we had the solar cover on Friday night. I also noticed them on the skimmer socks, so it is more than just the steps.
    Pictures attached. Any help with identification is appreciated.
    [attachment=0:5zvz8n0h]DSC_2873-1.JPG[/attachment:5zvz8n0h]
    [attachment=1:5zvz8n0h]DSC_2870.JPG[/attachment:5zvz8n0h]
    Southcentral PA
    Dec 2007
    Central New York
    504
    Re: Worms?
    Some bug just layed her eggs on the pool vinyl or on the coping. I wouldn't worry about them. Keep the skimmer sock on and brush the sides and bottom to get them floating and the skimmer will do the rest.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Jun 2007
    SouthCentral PA
    13
    Re: Worms?
    Just an update. There have been significant amounts of small flies around the pool, somewhat mosquito like. After much research, I am quite certain they are midges. I suppose they are the reason for the worm-like larvae in the pool.
    Link to Midges - http://bugguide.net/node/view/52163
    Southcentral PA
