Results 1 to 8 of 8
Thread: Need sand filter ASAP
    My Doughboy Silica II running off of a 1. 5HP Hayward Power Flo LX has 3INCH Crack. It's 12 yrs old. Looking for good relatively inexpensive replacement. Any ideas?
    Thanks
    Joe
    Thanks, Joe
    New Jersey
    - 15ft round Above Ground pool with vinyl liner (10 yrs old)
    - 5700 gallons, Sand Filter, 1.5hp pump
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Need sand filter ASAP
    Check your local craigs list.
    Do you think its ok for the pool to not be filtering for a few days? What can I do to prevent any harm to my water while not filtering. I'm in NJ.. been in the upper 80's this week and humid.
    Also, my current filer is 16" with a 1.5hp pump. Was thinking of getting this in 16". That should good, right?
    Or should I get the 18" ?
    http://www.amazon.com/Hayward-S180T-...pr_product_top
    Thanks, Joe
    New Jersey
    Apr 2011
    Murrieta, CA
    2,360
    If you have the funds go larger. Keep adding chlorine, brush down the sides, to mix it in. Dead stuff will fall to the bottom, it's better than fighting an algae bloom. Vacuum when you get your filter working.
    Quote Originally Posted by bobodaclown View Post
    $16 difference between 16" and 18".
    Is there a technical reason why I should get the 18 over 16 ?
    Thanks, Joe
    New Jersey
    Apr 2011
    Murrieta, CA
    2,360
    Large filter, can hold more before having to backwash/clean the filter.
    Any ideas in the meantime on how to stop this ?
    https://www.dropbox.com/s/8qhb93mthh...2018.57.47.jpg
    Thanks, Joe
    New Jersey
    Apr 2011
    Murrieta, CA
    2,360
    I think putting the multi valve into bypass should bypass the filter.
