Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Please look at my return / jet flow.. Is this right?
    Jun 2014
    Youngstown, OH
    182
    Just got my pool installed and want to make sure the return is pointing where it should and acting as it should..
    http://youtu.be/aa9uV1Rsu74
    Installed in 2014 - 24' Round x 54" Bliss XL Above Ground Pool 14,090 gallons // Hayward S270T Pro Series 27-Inch 350lb Sand Filter // Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed //
    Installed in 2015 - Hayward H200FDN Natural Guess Heater // K-2006 Test Kit
    Youngstown, OH 44514
    Jun 2014
    Michigan
    62
    Re: Please look at my return / jet flow.. Is this right?
    Never owned a round pool but it would seem to me that ya need to point it to get a counterclockwise flow to get the leaves/debris into the skimmer before they sink to the bottom. I adjusted my inground jets to maximize this and its working great. Less leaves/debris to fish out the better.
    We have these to adjust the direction....
    20K gal, Fiberglass, 1.5 hp Century Pump, Sta-Rit System 3 Model PLM-100, 100 SQ Foot. Inline Frogger Chlorinater Mineral pack removed, adjusted the Chlorine pac to put in my own when on vacation. Liquid Pool Sanitizer,, BBB style.
    Jun 2014
    Youngstown, OH
    182
    Well that's the thing.. Mine doesn't seem to turn, nor have a device like yours that allows it to turn..
    Aug 2010
    Dallas, TX
    4,052
    Loosen the ring around the eyeball and it will then be easy to move.
    Jun 2014
    Michigan
    62
    Quote Originally Posted by RobbieH View Post
    Exactly,,,,,
    Sometimes mine get a bit stuck. I >> carefully << use a 1/2 inch wood dowel rod about 3 inches long to convince it of the direction i desire. Now if I could get one for inside the house.
    If ya point it up towards the surface as far as she will go, tighten up the locking ring and bingo, ya got a po boy water feature.lol
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Mine is ghetto. I tried the eyeball when I put "real" fittings in my intex but it was too restricting so I grabbed a threaded 1.5 inch pvc elbow I had left over from my project and screwed that in instead of the eyeball. Voila! Instant whirlpool! lol
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Aug 2010
    Dallas, TX
    4,052
    These work well on my pool, but then I run my pump at low RPM.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
    Jun 2014
    Michigan
    62
    Quote Originally Posted by Beens View Post
    Thought about doing something like your ghetto jet system.lol,,, with a T or 4 way, cap and valve off to adjust for a sprinkler & reg flow water jet. Just another pipe dream.lol
    Jun 2014
    Youngstown, OH
    182
    The ring seems to be the entire piece!! There is just one piece it seems.. If I loosen "it" that is all there is!!
    Aug 2010
    Dallas, TX
    4,052
    Stop the pump and completely unscrew it (take out the eyeball). See if it comes apart. It's harder to do this if the pump is running.
    The part to unscrew is the ring the arrow is pointing at. Not the one against the pool, but the next tier.
    Jun 2014
    Youngstown, OH
    182
    Ok so if it unscrews then what? There's not another piece in there. Thanks
    Aug 2010
    Dallas, TX
    4,052
    The somewhat spherical part with a hole in it should separate from the ring you unscrew. I'll go get one of mine and post some pictures. If it doesn't, you can order the type you need from Amazon (or whoever you want to buy from).
    Aug 2010
    Dallas, TX
    4,052
    Jun 2014
    Youngstown, OH
    182
    Sweet thanks a lot! So May I need to take some pliers to get that thing loose? I tried with my hand and it wasn't budging..
    EDIT TO ADD: Do you agree that my flow (as seen in the video) should not be going that way?
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    572
    Try shutting the pump off first then you should be able to loosen it.
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Aug 2010
    Dallas, TX
    4,052
    If the pump is off and you still can't turn it by hand to tilt or remove, it sounds stuck!
    You need to circulate the pool, yes.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    I have a couple of nozzles that are a fixed direction. And some with adjustable eyeballs. He may have the non adjustable type.
    24'x40' 25k gal Imperial Mountain Pond IGP, full 28 mil VynAll Ocean Breakers liner. All Hayward system: 140k BTU HeatPro heat pump, 3/4HP single speed TriStar 2" Pump, DE6020 filter, AquaPlus Automation/Salt Chlorination, remote controls, ColorLogic 4.0 lighting. Polaris 280 w/PB4-60 BP. TF100 & K1766 test kits. Rinox Palazzo pavers and Spherik coping. Pool installed 9/2013, project completed 6/16/14.
    Aug 2010
    Dallas, TX
    4,052
    Agreed. Taking them out will tell the tale.
    Adjustable ones are inexpensive.
    steveg_nh's Avatar
    Oct 2013
    Southern NH
    832
    One day I'll replace the two of mine that are fixed.
  20. Back To Top    #20
    Jun 2014
    Youngstown, OH
    182
    So I must admit I'm not the strongest person in the world.. But I also think I'm not the weakest... I turned the pump off and I cannot get that thing to budge!!!!!
    Pliers? Then I'm afraid I'm gonna scratch or break something..
