Page 1 of 3 123 LastLast
Results 1 to 20 of 53
Thread: Water still cloudy. Why? Please help!
    Jun 2014
    Panama City florida
    36
    Here are my test results
    CYA 20
    CL 5-10
    CC 0.5
    FC 3.5
    PH 7.2
    Alk 40
    Can someone please tell me if my CYA being low the reason my water is still cloudy? What should I do to get my water clear again?
    16x48 Pro series AGP with a sand filter. About 6000 gallons of water. TF-100 kit.
    30,131
    Re: Water still cloudy. Why? Please help!
    Your water can be cloudy for any of a hundred reasons so you have to start learning more so we can help you get it figured out.
    Can you tell us your CH? If you know it is below 400, don't bother, but if you don't know that, test and post it up.
    1. What are you using to chlorinate?
    2. How old is that filter? Might be time for a new one. See any tears, holes, etc.
    3. How does your pump sound? Like new? Getting good flow into the pool?
    4. What are you using to vacuum your pool?
    5. When was the last time you put any
    CYA in the pool?
    Jun 2014
    Panama City florida
    36
    I was told not to worry too much about my CH because I have the pump that comes with the pool. All plastic, original pump that came with the pool. I added CYA a couple of days ago. I use the vacuum that also came with pool. The one that can either use a water hose or the pump itself. Just changed filter yesterday & pump sounds like it always does & has good flow. I am using great value bleach. And yes ch is below 400.
    Aug 2010
    Dallas, TX
    4,052
    CH matters because if it's high, it can cause cloudiness. This has nothing to do with the pump or filter. But like he said, if you have CH in range, it doesn't matter.
    Jun 2014
    Panama City florida
    36
    Ok. I can see the bottom of the pool it's just not crystal clear. Can I go ahead & let the kids swim? Been working in this for 2 weeks & wld really like to start using our pool. Thank you.
    Aug 2010
    Dallas, TX
    4,052
    What is the CL number? If it is TC, the math doesn't work.
    Jun 2014
    Panama City florida
    36
    CL is chlorine drop test & TC is 4. CH is 50.
    Jun 2014
    Panama City florida
    36
    Is it safe to let my kids swim? Or do I need to do more? Thanks for all the help.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    How long do you run your pump?
    Jun 2014
    Panama City florida
    36
    24 hours a day for the past week an a half
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    I got my pool clearer with the stock pump using knee highs over the skimmer or if no skimmer, over the return. I may have efen olaced one over the cartridge at one point. It never got sparkly clear until I got a sand filter. But it got pretty nice with the cartridge.
    Jun 2014
    Panama City florida
    36
    It used to be sparkly clear until I got a bad case of algae build up. I could deal with the cloudiness for now (even though I would prefer to get it cleared) I just want it to be okay for my daughter to get in it. She has been waiting patiently for 2 weeks, but is now getting inpatient. Especially since 4 weeks ago it kept storming for 2 weeks & now I have been cleaning for 2 weeks. So in total it's been a month since she's been able to get in. So if you could please tell me how to get it completely clear & if it's ok for her to get in now? Thank you so very much.
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    If your numbers are good, I'd try the knee high panty house over the filter. It will help get out the little stuff.
    Did you pass the overnight loss test?
    Jun 2014
    Panama City florida
    36
    Didn't quite understand how to do that. Can my daughter swim while I do the panty hose?
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,273
    Safety first when it comes to swimming. If it is too cloudy to see a swimmer in any part of the pool, it is unsafe to swim. If your free clorine FC is too high for your CYA, it is unsafe to swim. Unfortunately, your test results don't make sense, so we can't tell if your levels are safe.
    Duraleigh asked questions, we need your answers to those questions in order to help guide you.
    What test kit are you using to get your results? I ask because some of your results do not make sense. Test strips and pool store results are very unreliable. Without reliable test kit results, it is impossible to give advice to clear your pool. http://www.troublefreepool.com/conte...its-comparison
    Once you get reliable test results from one of the recommended test kits, we can help you clear your pool and with the knowledge gained here, you will never have to worry about a cloudy pool again.
    In the mean time, please read pool school and you could add a few cups of plain unscented bleach a day. This will keep algae from getting worse, but won't necessarily kill the algae. To get rid of algae, you will need a one of the recommended test kits and complete the SLAM process:
    http://www.troublefreepool.com/conte...tain-shockingl
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2014
    Panama City florida
    36
    I did answer the questions in above post. I have the TF-100 & I have read pool school. Have been using unscented bleach. The answers to his questions are right below his post. I am following the directions to the test step by step and exactly as told. What about my results do not make sense?
    Butterfly's Avatar
    South Carolina
    10,045
    Using your test kit, please post these test results for us:
    FC
    CC
    CYA (if you have added CYA in the past week, rather than test, just tell us how much you added)
    pH
    TA
    You're done SLAMing when:
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,233
    In your first post you listed chlorine as 5-10. That is a pretty big range, however for your CYA of 20 your FC target is 2-5ppm and slam level is 10ppm. As long as you are at or below slam level and you can see the bottom of the deepest part of the pool it should be safe to swim.
    Love TFP? Become a
    TFP Supporter!
    Jun 2014
    Panama City florida
    36
    Okay. I tested again. I put about a cup of CYA a couple of days ago.
    FC 3.5
    CC 0.5
    TA 400
    PH 7.2
  20. Back To Top    #20
    Jun 2014
    Panama City florida
    36
    My test has a it listed as 5-10 & then it goes lower. In reply to zea
    Last edited by Kacalhoun; 07-08-2014 at 10:57 PM. Reason: Wanted to say who the post was for
