Page 1 of 3 123 LastLast
Results 1 to 20 of 50
Thread: chlorine acid vanish, CYA vanished, bad pH reagent and non-ergonomic spoon
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    Am following TFP advice and pool is fine and pretty much matches PoolMath.
    FC 5
    CC 0
    pH 7.6
    TA 80
    CH 250
    CYA 30
    But it soaks up chlorine and acid like a sponge. Am using 5.25% bleach from local hardware.
    So set out to find stronger chlorine and found the HASA web site
    <http://media.hasapool.com/productpages/P-1.pdf>
    seems like an Ok company
    where I see recommended
    FC 1.5 to 3
    CYA 60 to 80
    the TFP chlorine/CYA chart shows at 60 CYA a min FC of 5
    so am confused? how to explain the different recommendations?
    Thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: confused about HASA web site info
    This site recommends that the CYA amount drives the FC amount.
    You can read more about it here:
    http://www.troublefreepool.com/conte...art-slam-shock
    http://www.troublefreepool.com/conte...at-is-tfpc-bbb
    more in-depth reading: http://www.troublefreepool.com/threa...rine-CYA-Chart
    A large number of companies publish recommended levels that date back 60 years or more to the time before anyone knew what CYA did. These outdated recommendations just get copied from place to place, and no one ever bothers to update them to actually work with CYA.
    Jul 2012
    Whidbey Island, WA
    397
    thank you, I suspected same
    so then
    is there any way to reduce the powerful suck of chlorine and acid
    to reduce it from 1.5 gal 5.25% bleach and 1 pt acid / day
    or
    is that just the cost of doing business in the summer, the cost of enjoying grand baby giggles
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Quote Originally Posted by engrav View Post
    so then
    or
    That's a BIG pool. 2.5 gallons of 5.25% is only 2.7 ppm/ day chlorine. That's not bad if the pool gets a lot of use
    Apr 2011
    Murrieta, CA
    2,360
    You shouldn't need to add acid daily (weekly), and chlorine is a daily chore, but looks like you have a SWCG, so that task should be done automatically. With a SWCG you should have a higher CYA level (70-80).
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by bobodaclown View Post
    as above, Ok a BIG pool and it will suck up stuff, got it; so must figure out how to avoid ≥45 empty bleach bottles / month; will search for a 12.5% bleach method
    but I do need to add acid all the time; diary shows I added acid 6/26 6/28 6/30 7/2 7/4 and 7/7 (I guess not quite daily)
    SWCG? do not have that; if something wrong in my signature I should fix that
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    With only 30ppm CYA, you will be losing a lot to the sun. Try raising it to 40ppm and see how it behaves.
    30,419
    read "The ABC's of Pool Water Chemistry" up in Pool School.....all those answers are there. I will add that chlorine consumption is driven by two things ONLY. UV on the pool water and organic materials in the pool water. There is NOTHING else that consumes your chlorine and a principle that many of us "seasoned" pool nerds" often forget
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    Have read it many times and in accord, moved from swamp with two dead rats to a pristine beauty (IMO)
    Have now moved from how to fix to how to reduce the acid/chlorine burden; cannot process 45 empty bleach bottles each month
    I like Richard320's signature
    Richard320 said is a BIG pool; ok then gotta just suck it up so to speak
    JohnT said bump CYA to 40; could do that
    several have said get higher % chlorine; could do that
    jblizzle said test OCLT at higher FC; could do that
    ABC says high TA cause up drift of pH but I do not have "high" TA
    but then 257WbyMag said in another thread let TA drop to 70 or 60; could do that
    there is a Rainbow turned off; could drop in a tab or two
    so will try all these tweaks thank you but
    after I jump in tomorrow to remind myself why I am doing this
    Aug 2010
    Dallas, TX
    4,052
    My pool is 44k gallons. If you are on the bottle (bleach), you might consider going salt. Buying bleach and daily maintenance of a large pool takes a lot of effort. Standing by the pool and adding the bleach might not be that different than a small pool, but buying and hauling bleach bottles got old for me really quickly.
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by RobbieH View Post
    that may be the long term answer
    but will try the little tweaks over the next weeks
    thanks again
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    Just bought some 12.5% liquid chlorine. Should reduce the # of empty bottles.
    Nice store, no retail fancy stuff, just a pool service. And the man seemed quite knowledgeable. He also suggested SWG.
    pH of the stuff is 11.2
    this might explain my acid burden
    he said several of his commercial pools with liquid feeders also have acid feeders
    several tfp threads comment on this as well
    so maybe I do not have two problems, just one; jugs and jugs of liquid chlorine
    Aug 2010
    Dallas, TX
    4,052
    The pH from adding liquid chlorine ends up being almost neutral. The pH is shifted back as the chlorine is consumed.
    Anything that aerates the water, including splashing, drives up pH and necessitates adding acid. Bubblers, waterfalls, negative edge pool, etc.
    Jul 2012
    Whidbey Island, WA
    397
    so I set out to work on the tweaks to see if can fix too many empty bleach bottles and too many additions of acid
    started by tracking FC today, very sunny day
    here it is
    5:00 FC11
    8:45 FC 8
    12:00 FC 6
    1:44 FC 4
    3:45 FC 3.5
    5:50 FC 2.5
    I also had not tested CYA for a couple of weeks so did same and found that
    little black spot shows even if comparator full so not much CYA
    I don’t have liquid CYA out here so
    at this point I turned on the Rainbow with 5 tabs and setting 3 since the tabs have CYA
    then
    8:44 FC 2.5 (of course sun is gone now)
    will see what happens tomorrow
    as per another thread, my funky too intense pH color discussed in Oct last has returned so pH as the FC declined was doubtful; but it did not change as FC declined, funky at the start, funky at the end
    Jul 2012
    Whidbey Island, WA
    397
    with 5 tabs in the Rainbow and setting 3
    FC stayed between 2.5 and 4 all day, even with hot sun
    NO EMPTY BLEACH BOTTLES! PRAISE THE LORD!
    and CYA should have gone up a little (still < 30 however)
    will leave the Rainbow run all weekend and get some liquid CYA tomorrow in Bellevue
    also new bottle of R0004
    pH test remained funky all day so not reporting, did not change as FC went down, have ordered TF-100, then can compare to K-2005
    by the way, IMO the little blue spoon is poorly designed
    if you lay it flat side down, it is hard to pick up
    since the handle is flat, it is hard to rotate to dump
    since all other stuff is so slick, seems tftestkits.net oughta get a new spoon
    could be called the troublefreespoon
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    I like the comment on the spoon. I have learned to always put it back in the box right side up so I can get it out.
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    You can modify your scoop to make it easier to handle. Either wrap the end in electrical tape so it gives it a little bulk and lifts it off the flat surface, or use a lighter to soften the end of the handle for about a second and bend it slightly up. Hold it in the desired position and blow on it to cool the plastic. It will hold the new shape. Just did this to mine as an example.
    Love TFP? Become a
    TFP Supporter!
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    about the chlorine acid sink
    pool is doing fine with Rainbow on 3 with 5 tabs
    this AM FC 3.5 and no empty bleach bottles
    pH still funky but 7.8 with 3 drops
    CYA still <30
    will get new R0004 and liquid CYA today
    as for the spoon
    will try your bend it up fix
    person at TFtestkits replied no one else has complained so spoon unlikely to be changed
    but now there are 3 and 3≠ 0
  20. Back To Top    #20
    Jul 2009
    Houston, Texas
    9,379
    Well, he doesn't make the spoons and if you do a google search you will see there is not a lot of diversity of design in the tiny scoop market. That leaves it up to the user to make the modifications they need to optimize function.
    Love TFP? Become a
    TFP Supporter!
