Thread: Filter pressure dropped from 15 to 5 PSI
    I was working on the pool; everything ok. Heard a click noise from the pump area and then the filter pressure dropped from 15 to 5 PSI. Water is still flowing through the pump/filter, but lots of bubbles in the pump basket, very slow water flow from the return. Replaced the pump basket o-ring, released air from the filter, flashed the pump to skimmer line via garden hose just in case there is any clog or so; but still no luck. The pressure is really low.
    Any thoughts? Did the pump broke (please note that the pump is still running)? What else I can do before spending couple of hundred dollars to replace the pump.
    Thanks in advance for your advice.
    NUbee!
    Rancho Santa Margarita, CA
    Gallons? Unknown. Medium sized pool.
    Filter? I think cartidge. Big beer can looking device with pressure valve on top running around 30 PSI
    Inground plaster pool.
    Spa above spills into pool. Waterslide above Spa spills into pool.
    Heater: Purex Triton MiniMax
    Vacuum: Hayward Navigator
    Pool guy does regular water maintenance.
    Re: Water flow slower - where should I start?
    Thanks, I tried that, but still no luck. Do you think something happened to the pump? This is still running, but I did hear a click noise right before the pressure went down.
    NUbee!
