Thread: Pump Issues Revisited
    Jun 2013
    Augusta, GA
    90
    About a year ago, I was having some strange issues with my pump: When turned on, it would make a noise similar to bad bearings, then trip the breaker. It would only do this under conditions where there was little return pressure (Backwash, Rinse). My solution was to constrict the backwash hose for a second, and the grinding noise would go away and the pump would operate as normal. For some reason this condition rectified itself after a few months.
    Fastforward to this weekend, the problem returned, but now on the normal filter function. I checked the baskets, and there are no obstructions.
    My current solution is to stick a finget in the return eyeball in order to increase return pressure while I turn the pump on. It seems that this increased return pressure helps the pump 'work through' the gringing noise and then contunues to operate normally.
    To sum it up: Increased return makes my pump not trip the breaker.
    Any ideas on what the issue is?
    30'x52'' AGP 21,000 Gallons
    TWM 2.64 SF Sand Filter w/ Century 1.5 HP Pump
    BBB'er for life!
    TF-100 Test Kit
    22,543
    Re: Pump Issues Revisited
    Sounds like a loose impeller that's touching the casing front until the pressure builds a little. Have you taken the wet end apart?
    Jun 2013
    Augusta, GA
    90
    Thanks for the quick reply! I have not taken anyting apart, was looking for some feedback before I moved forward. Going to see if I can get it on the bench tonight.
    BBB'er for life!
    TF-100 Test Kit
    Jun 2013
    Augusta, GA
    90
    Well, I took the pump off the motor and everything looked good, but the problem still persists. Looks and sounds like it might be the rear bearing. I took a video, how do I post it?
    BBB'er for life!
    TF-100 Test Kit
    Aug 2010
    Dallas, TX
    4,052
    Post it to something like Photobucket then link here.
    Jun 2013
    Augusta, GA
    90
    BBB'er for life!
    TF-100 Test Kit
