Results 1 to 8 of 8
Thread: Where to start ..
    May 2014
    Addison, TX
    4
    Where to start ..
    Good day to the experts!
    We just purchased our first home and moved in last week. We are thrilled and could not be more excited about the pool. Knowing we were going to be pool owners for the last few months I have done a ton of research and decided I wanted to go with the TFP/BBB method of pool maintenance. One walk through the local pool store looking at their prices had me convinced.
    Moving on to the important details:
    I received my TF100 kit last night and ran all the tests this morning.
    FC - 4.5
    CC - 0.5
    CH - 550-650 (Tap water was 200)
    TA - 180
    CYA - 100-120
    PH - 8.2
    Temp - 85
    Clearly the previous owners used tablets as evidenced by the high cya and empty buckets in the shed.
    The pool does have a little algae on the sides and I have been brushing daily, the water is clear and generally looks good. I had been dumping a jug of Clorox in every evening for the last week while waiting for the kit to arrive and that has helped tremendously.
    I have read pool school in depth and many other threads, so I have a good idea that a Slam is in my future and a water exchange.
    So my question is where do I start with attempting to level and stabilize the pool?
    My other issue is with the DE filter, I took it all apart last night and hosed everything down. The pressure gauge was broken so I ordered and installed a new one from TFT. Now my pressure displays over 25psi and I haven't even add the DE yet. Is there anyway that once I add it the pressure will drop? That seems counterintuitive to me, so what could possibly be wrong with the filter. I did backwash again once it was all together and the pressure did not change.
    Thanks in advance for all the help!!
    Outdoor free form gunite party pool approx 15000gal. Hayward single speed 1hp pump and 2420 DE filter. More info to come...
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    Re: Where to start ..
    I would start by replacing water to get CYA to around half of what it is now (or even lower). Then I would SLAM the pool.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    May 2014
    Addison, TX
    4
    Ok I figured out the filter issue. I had the Polaris hooked up and the jandy was directing all the return water to the cleaning return port obviously this was creating way too much pressure. As soon as I disconnected the Polaris the pressure returned to normal! Problem #1 solved!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    While I agree long term you need to get teh CYA down, getting the pH down is something you can do today. Use Pool Math to figure out how much Muratic Acid you need and get that into range today if possible.
    With CYA at 120 your FC should be around 13 - 14, but never below 9. Once you get the pH fixed get eh FC up to 13 - 14 until you either figure out how you will reduce the CYA or when you start the SLAM.
    A SLAM at CYA 120 is very expensive. To give you an idea, these ar the shock levels for differing CYA levels:
    120 46.7
    100 39.1
    90 35.2
    80 31.4
    70 27.5
    60 23.7
    50 19.8
    40 16.0
    Quote Originally Posted by chem geek View Post
    The shock levels shown have equivalent disinfecting chlorine amounts (in a column) but at high CYA levels it may be impractical to use such high FC levels. A partial drain/refill to lower the CYA level is usually what is needed or one can shock at a lower level but will take longer to kill the algae.
    Support the site
    May 2014
    Addison, TX
    4
    The drain is underway!
    It is somewhat sad to see all that water flowing down the street knowing what a drought we are in. Hopefully this is the last time I have to do this. Makes me wish people would take care of their things.
    May 2014
    Lewisberry, PA
    93
    Quote Originally Posted by FlyingMoose View Post
    Most pool owners are clueless and are trusting in the "pool store" to guide them in their pool maintenance. The poor suckers don't have a chance! You made a great decision to become proactive in educating yourself and learning how to properly maintain your water through TFPC. It might be a hassle now, but once you get through it and understand how to keep your pool from becoming a swamp, you will jump for joy every time you jump in that sparkling pool! Good luck and Congratulations on finding TFPC.
    16,000 gallon Oval Vinyl Liner Pool (new liner 2014)
    Custom built in 1999 to be half in-ground and half out (sloped yard) vermiculite bottom, laser sighted to Florida Room and Deck
    Purex Triton Model cc100 Cartridge Filter, 100 gpm flow rate, Penfair 1HP Pump
    TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Make sure the lawn has absorbed all it can before you let it go to waste!
    Oh, and welcome.
    May 2014
    Addison, TX
    4
    Oh, and welcome.
    I sure did. I walked around with the backwash hose flooding the whole yard as much as I could.
    Refill is almost complete the I will run all the tests again and post updated numbers.
