Thread: Inteliflo VS or I1 for smaller plumbing?
    Jul 2014
    PINOLE,CA
    7
    Hi noob here
    I have been shopping around for a VS pump and doing some research for a few weeks now and
    one of the dealers told me I should go with a inteliflo I1 model because of my smaller piping.
    Then other dealers told me the regular inteliflo VS would be fine for my system
    My pool is approximately 17K gallons with 7 solar panels on a single story rooftop, a 400sf filter and a Polaris booster pump for the cleaner.
    The plumbing is 1 1/2" on the skimmer and return but is enlarged to a 2" to connect to the suction of my current 1hp filter pump and 2" pvc run to my solar and back down before it is reduced back down to 1 1/2" going to the return.
    Should I believe the dealer that says I1 because he knows what he's doing? Or is he wrong and the only benefits of the I1 is for areas(counties) that are restricted by flow due to regulations?
    Any comments and suggestions are will appreciated in advance!
    Thanks
    38,527
    Re: Inteliflo VS or I1 for smaller plumbing?
    Welcome to TFP!
    Those 2 pumps are almost the same. The i1 is just speed limited and I think has a smaller impeller. You could use either.
    There are smaller VS pumps on the market now as well that are cheaper although a little limited in automation.
    Do you have a solar controller? A smaller 2 speed pump may make more sense from a cost perspective.
    Jul 2014
    PINOLE,CA
    7
    Welcome to TFP!
    Yes, I have the Suntouch controller that is why I'm leaning on the Inteliflo VS since it can control it by the RS-485 cable.
    I don't mind the initial cost investment as our electricity rate is high here in CA.
    Thanks for the reply jblizzle!
    38,527
    That might control a 2 speed pump as well. If not, then get one of the Intelliflo pumps. You can always limit the speed of the full size version.
