Thread: Best source for plumbing for an equipment pad?
    So, what is a good, economical source for pool plumbing?
    I need PVC/CPVC elbows, reducers, unions, valves, etc... In both CPVC (for the heater connection) and PVC (for everywhere else)...
    Local big-box stores don't carry a whole ton of 2" stuff in stock, most of it is "special order", and that that point I might as well just try to find the best price online, which is what this thread is about. Local pool supply places are *NUTS* on simple unions, let alone valves, so they are out unless I have an emergency and need something on the quick, then the premium is worthwhile.
    I am on a really tight budget, not because I am cheap, just because of the scope of what we have going on. I got great deals on the equipment (for example a 1.5hp Pentair Dynamo 2-speed pump, brand new for $160 shipped, or a new Laars LG250P heater for $280) which made a lot of this possible, I just can't have the plumbing kill getting things completed.
    Any and all referrals are appreciated.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Best source for plumbing for an equipment pad?
    For <= 2" pipes and fittings I have found nearly everything at Lowes and/or HD. What are you having difficulty finding?
    For Jandy valves and other specialty items, online is probably the most economic.
    For 2 1/2" pipe and fittings, I usually go to a local irrigation store.
    Mark
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I bought all my 2" at Lowes. You can see prices online. Mine was PVC. I'm not sure what their CPVC stock is like.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
