Thread: why is my pump losing pressure after 10 minutes
    Jul 2014
    Erie, Pa
    6
    Filter is EC65, pump is a Heyward-not sure of size but runs on 220
    Pump loses pressure (gauge reads 30) after about 10 minutes. When I shut it off I bump the handle and turn it back on. Again, it runs good for 10 minutes or so. I've changed the earth in it several times and it really doesn't make a difference (maybe 5 minutes more before losing pressure). It does not lose pressure if I bypass the filter when vacuuming the floor. Yesterday I noticed a very small amount of water that appears to be coming from under the pump. It's not a lot, I just know that it shouldn't be there when everything else around is dry.
    Note: both filter and pump are over 15 years old. What is the expected life of these?
    38,243
    Re: why is my pump losing pressure after 10 minutes
    Welcome to TFP!
    When is the last time you opened up the filter and cleaned all the fingers well?
    Jul 2014
    Erie, Pa
    6
    fingers were cleaned when I closed the pool up after the last season
