Results 1 to 8 of 8
Thread: not opening pool ??,s
    Jul 2014
    kamloops bc
    39
    So I will not be opening the pool this summer! It was put to bed last Sept. with clear balanced water, with non chlorine shock, sequestion agent and algecide. It is covered with a black tarp. Usually opens up with clear water. However I'm worried about leaveing it now till next summer. It will see some very hot weather!! Should I be trying to add something to water?? or will the lack of light keep the alge at bay??
    Marc
    Jul 2014
    kamloops bc
    39
    Re: not opening pool ??,s
    u hoo! experts?? :>))
    14 x 28 IG, Hayward sand filter, Hayward 3/4hp pump, auto puck chlorinater,(used only when away) Hayward Natural gas heater, vinyl liner
    38,242
    You can not ignore a pool that long without problems developing. Either deal with cleaning it up next year or maintain the chemistry.
    Jul 2014
    kamloops bc
    39
    Kinda what I figured :>((, I was thinking about uncovering a corner and adding chem. but will have trouble mixing properly, so will leave it be and deal with it next summer. I'm just hopeing it does not permantly stain my liner! Clearing up a green pool is not the end of the world for me. Unless someone with experience warns not to?
    Marc
    Butterfly's Avatar
    South Carolina
    10,045
    Ignore a flower and it will die.
    Ignore a pool and it will come alive
    You're done SLAMing when:
    Jan 2012
    'burbs of Augusta, Georgia
    7,259
    Quote Originally Posted by shockman View Post
    Marc
    Drop a small sump pump down in there with your chemical additions with the hose returning the water back immediately in to the pool and let it mix up that way.
    Jul 2014
    kamloops bc
    39
    Quote Originally Posted by YippeeSkippy View Post
    Good idea! what should I be adding for chemicals? 14x28 with about 18" in shallow end and 5ish feet in deep
    Jun 2013
    East TN
    309
    I used a sump/utility pump over the winter to add chlorine and mix it up. I have the pump in a bucket rigged up with rope, a weight, and piping on the pump to pull water from the bottom and to put it on top (turnover). Worked great for me. When you unplug the pump leave it in the water for about 30min because the pump will get blazing hot if removed imediately. I got mine off craigslist but Lowes carries them.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
